cannot open shared object file
I'm trying to write a sop that accesses PRman's pointcloud API. Everything seems to compile and link properly but when I try to bring the sop into Houdini I get this error:
libprman.so: cannot open shared object file: No such file or directory
In my makefile I have:
LIBDIRS = \
-L$(RMANTREE)/lib
LIBS = \
-lprman
is there something else I need to do to tell Houdini where this library is?
I don't know if it would be of any use but I just released some open source HDK code for loading & previewing prman point clouds into Houdini.
http://danbethell.github.com/rmanptcsop/
cheers,
dan
p.s. as to your specific question - yup (as Edward suggests) check your runtime library path (LD_LIBRARY_PATH or DYLD_LIBRARY_PATH on mac).
Thanks guys, adding prman's lib directory to LD_LIBRARY_PATH did the trick.
Dan,
The code you linked is actually really similar to what I'm working on. I'm building this as part of an independent learning project for a University class, so I'm going to hold off on looking at your code for a bit until I develop my own solution, but I'm really interested to see how you went about it. Thank you for letting me know about your project!
