Procedural Spider Generator
Esther
I am studying at IGAD in the Netherlands which is a game design education. For last block we had to do a project in Houdini. I like animals and everything organic, so i ended up making a system which randomly creates different spiders.
There are also controls which let you adjust a generated spider.
I couldn't figure out how to post in the finished projects topic so i'll just post here.
Here are some spiders that are randomly generated:
here i made two spiders after an example by using the controls.
A tarantula
A green spider
Buttoms-up:
Hairy-spider:
houdini crashed around 150000 hairs :P
What i basically did is start with a shape for the spider's head. This shape is adjustable. The legs and abdomen are connected to the head's shape. So when the head shape changes, everything changes with it and keeps its connection to the body.
If you have questions, ask :)
Good stuff. Can you create a bunch of random spiders at once or one by one?
No there is just one spider on the screen and its dimensions change on each frame.
It is done by the following construction rand($F). So you get a random value which changes on each frame.
you can use that value between 0 and 1 for everything. The expression i used most was:
fit(rand($F+24),0,1,45,90)
With fit you can scale the random value between 0,1 to a value between 45 and 90 for example.
