jumper Posted February 9, 2010 Share Posted February 9, 2010 Hi, I am using the generic mantra reflective material. I would like to use a lat/long environment map (from a light probe originally) in the tab surface->reflections->environment map(instead of ray tracing the image). But I am not sure how to set it up so that I can view and change the orientation in the viewport. I am also not sure if lat/long instead of the cube/cross works. Any help would be much appreciated! Thanks Quote Link to comment Share on other sites More sharing options...
