mightcouldb1 Posted February 21, 2010 Share Posted February 21, 2010 I have some rotating instanced geo that I am using in POPs. I was wondering if it is possible to create a cookie between the instanced geo and another object. ...or is it better to do some copy stamping and create the rotation in SOPs? Thanks! Jason Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted March 1, 2010 Share Posted March 1, 2010 I have some rotating instanced geo that I am using in POPs. I was wondering if it is possible to create a cookie between the instanced geo and another object. ...or is it better to do some copy stamping and create the rotation in SOPs? Thanks! Jason No... you need to pre-build the model before instancing. And after that you can only change a limited number of parameters. Before go with instance objects build your network with copy/sop. So you can pre-viz it. Copy/Sop also gives you more freedom to work. So if don't need a extremely huge number of objects. Go with copy/sop. Quote Link to comment Share on other sites More sharing options...
