Stalkerx777 Posted March 3, 2010 Share Posted March 3, 2010 Hi! Is it possible to add offsets in collision between wire objects? There is offset parm., but it's for volume collision.Maybe some trick? Didn't find answer anywhere... (( Quote Link to comment Share on other sites More sharing options...
anim Posted March 3, 2010 Share Posted March 3, 2010 for wire thickness there is Width parameter under WireObject/Physical Tab but be aware that if you change that parameter the whole mass of the wire will change according to the density attribute and new thickness giving you different look of the simulation so either compensate density parameter to the new width or set mass directly to avoid this dependency Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted March 3, 2010 Author Share Posted March 3, 2010 Thx anim, exactly what i need.! Quote Link to comment Share on other sites More sharing options...
