Can NOT get Entropy work with Houdini.
Thank you for your reply.
I used proto_install and select EntropyDisplay.inst. And the installation of the new display driver is successful because I can see the image in the mplay window. Also, /entropy/bin is in my path.
But when I open Houdini and try to add an Entropy Operator in the output pane. I can NOT find it there. The only things available there are: Mantra, OpenGL renderer, Subnetwork, Composite, 3D texture Generator and Wren 1.0.
