andrey_vl Posted March 6, 2010 Share Posted March 6, 2010 press play and see cam view. copy sop with grid is problem. grid "rotates". how i may fix it? copy_rot_z.hipnc.zipFetching info... Quote Link to comment Share on other sites More sharing options...
anim Posted March 6, 2010 Share Posted March 6, 2010 (edited) easiest way would be to do copying inside sphere object, that way it would copy only once and then transform of the sphere would take care of correct transformation since you are using object_merge into another geo which brings sphere at different transform each frame, you need to provide some hints for copy sop on how to rotate the copies this may be done as N and up point attributes on merged object you can create those attributes either on original object or after object merge using facet SOP and polyframe SOP in the file i have used them after object merge which may be preferable if you are creating an asset and you do not know if input geometry will have those attributes but having them on original geometry would be more efficient since it is not time dependent, at least on your example look at the file for both methods copy_rot_z_fix.hipncFetching info... Edited March 6, 2010 by anim Quote Link to comment Share on other sites More sharing options...
andrey_vl Posted March 6, 2010 Author Share Posted March 6, 2010 thanks Quote Link to comment Share on other sites More sharing options...
