nekhlym Posted March 17, 2010 Share Posted March 17, 2010 Hi i was trying to install hot on win 7 64 bit and have done as the documentation mentioned setting the env var for the HOUDINI_PATH and the PATH . but i can`t get it to work so i must do something wrong Quote Link to comment Share on other sites More sharing options...
eloop Posted March 17, 2010 Share Posted March 17, 2010 First question, can you build SOP_Star.C with hcustom ? -Drew Quote Link to comment Share on other sites More sharing options...
nekhlym Posted March 17, 2010 Author Share Posted March 17, 2010 i used the hotbin_win64_H10.0.465_1.0rc8 binary distribution should i try to compile it my self? Quote Link to comment Share on other sites More sharing options...
eloop Posted March 17, 2010 Share Posted March 17, 2010 I wasn't sure if you were compiling from scratch. So I take it you are using H10.0.465 ? What happens when you try and load sop_simple.hip ? Quote Link to comment Share on other sites More sharing options...
nekhlym Posted March 18, 2010 Author Share Posted March 18, 2010 yes are using the 465 version of houdini. When i load the file i get an error message. Warning: Bad node type found: Ocean in /obj/ocean. Quote Link to comment Share on other sites More sharing options...
eloop Posted March 21, 2010 Share Posted March 21, 2010 All I can suggest is rechecking that you have followed the installation instructions properly, are the paths correct etc. -Drew yes are using the 465 version of houdini. When i load the file i get an error message. Warning: Bad node type found: Ocean in /obj/ocean. Quote Link to comment Share on other sites More sharing options...
