Improving Spring SOP Collision
...using the Spring SOP (Thanks, Sirogi! ;) ) to make pigtails that bounce on a hyperactive model.
BUT
The occasional pigtail is sliding through the model's face (disappearing at the nose, reappearing at the chin) for a truly frightening effect.
I can't delete individual 'problem' strands because too many of them fail once (though they bounce properly 90% of the time).
any ideas?
Try increasing the Time Increment (Time Inc) parameter from 1/$FPS to 0.1/$FPS. This parameter determines how may times the spring SOP evaluates per frame. 1/$FPS evaluates on frames where 0.1/$FPS evaluates 10 times a frame.
  • 3 weeks later...
Is the collision geometry triangles? Houdini doesn't like to perform collisions on quads or others because of the possibility that some polys might be non-planar. So, if your collision geomentry isn't triangulated, you might try triangulating it with a divide SOP.
stu
