MENOZ Posted March 20, 2010 Share Posted March 20, 2010 hi, I have some questions about lights in houdini, I hope somebody could help me to understand how things works. 1- light template. there is a tab containing a "categories" parameter, what is for? 2- using a standard light i have access to some parameters and functionality without the needs of building and connect shaders together. I have the opportunity to specify a path to save my .rat depthmap to disk, and read it back later. How can I do this if I am using a light template with a VEX_shadow shader attached to it? I have only the opportunity to read the shadow back, buto i'm not allowed to write it to disk. How can I do? Quote Link to comment Share on other sites More sharing options...
symek Posted March 21, 2010 Share Posted March 21, 2010 hi, I have some questions about lights in houdini, I hope somebody could help me to understand how things works. 1- light template. there is a tab containing a "categories" parameter, what is for? Categories is an alternative way of linking lights and shading in Mantra. Check out SESI help: http://www.sidefx.com/docs/houdini10.0/light/lightandshadowlinking Catergory on light object is like a label (tag) for it. After such labeling you can use expressions on objects side (or vex functions) to select lights and object influencing this instance. 2- using a standard light i have access to some parameters and functionality without the needs of building and connect shaders together. I have the opportunity to specify a path to save my .rat depthmap to disk, and read it back later. How can I do this if I am using a light template with a VEX_shadow shader attached to it? I have only the opportunity to read the shadow back, buto i'm not allowed to write it to disk. How can I do? You need to add a set of render properties to tell Houdini this light is going to produce shadow map. These are vm_picture, res, render_shadowmp at minimum. Quote Link to comment Share on other sites More sharing options...
