cvex
hello,
I read the manual about cvex, and it says that it's a code that can be written in vex or my making a cvex VOP network.
I don't understand what exactly can be done with cvex. when should I use that?
I don't understand the difference from vex (or vop).
Can anyone explain me? :unsure:
CVEX is vex which drives c++ code. It can be used only on nodes/dso/plugins that were designed for it, like Mantra Fur Procedural or Mark Story's ClusterThis. So basically it has no purpose unless someone will write a node with cvex in mind. SESI provides HDK libraries to teach custom code to use vex.
