how to get python error output to the shell with OsX
pushpathadam
when I work with houdini in linux on python scripts that live inside an OTL, I can usually see
and catch errors from typo's in the external shell.
Anyone know how to get the same feedback behavior in OsX? I'm on snow tiger with 10.0.465.
I tried starting houdini from the terminal shell with "open" to mimic the usual linux workflow but no luck.
Is there some environment variable I need to set to enable output to stderror?
thanks
Tom
Got an answer from Graham on sidefx.
Basically run houdini in a properly initialized environment by first starting
-Houdini Shell.terminal
-type houdini
thanks
Tom
