CSN0309 Posted April 16, 2010 Share Posted April 16, 2010 hi~guys Can i keep a proper distance between each particles? i don't want two particles get too close with each other. (objects will interact with each other once i use copy node to "copy" object on each particles) thanks Quote Link to comment Share on other sites More sharing options...
Tong Le Posted April 16, 2010 Share Posted April 16, 2010 hi~guys Can i keep a proper distance between each particles? i don't want two particles get too close with each other. (objects will interact with each other once i use copy node to "copy" object on each particles) thanks maybe you can append a drag node in the POPs and twist the parameter in it. Quote Link to comment Share on other sites More sharing options...
CSN0309 Posted April 16, 2010 Author Share Posted April 16, 2010 ok~ let me try~ thank you, i have put interact node on it, now it appears have been separated together Quote Link to comment Share on other sites More sharing options...
