chop expression not works in the dop
sparkChan
hi,
I use the expression 'chop("../chopnet1/rename1/count")' in the dopobject. but if I change parameter of any dopobject,and recook simulation. then the expression doesn't work.
I must delete the expression, then check the 'Update' button in the Dynamic CHOP, and rewrite the expression, it works, why?
seeing the sence.
thanks
apply_rel.hipFetching info...
