kunal Posted April 23, 2010 Share Posted April 23, 2010 Hi im trying to animate a mesh made with different tubes. Basically its a formation effect where we see various circles form a whole mesh of tubes. I know how to do this in houdini by animating the U and V values on the carve tool but i cant use Houdini for this project. Anyone knows how to do the same thing in maya....I know how to extrude a circle on a nurbs curve. Just need to know the correct workflow for doing the animation so i can control the extrusion over a period of time. ur help will be greatly appreciated Quote Link to comment Share on other sites More sharing options...
mawi Posted April 23, 2010 Share Posted April 23, 2010 (edited) On 4/23/2010 at 7:58 PM, kunal said: Hi im trying to animate a mesh made with different tubes. Basically its a formation effect where we see various circles form a whole mesh of tubes. I know how to do this in houdini by animating the U and V values on the carve tool but i cant use Houdini for this project. Anyone knows how to do the same thing in maya....I know how to extrude a circle on a nurbs curve. Just need to know the correct workflow for doing the animation so i can control the extrusion over a period of time. ur help will be greatly appreciated When doing the extrusion you have to change from complete -> partial in the extrude option box(is that the name?). If you now look in you channel box you will have 2 inputs called subCurve1 & subCurve2. Animate the min/max values there. Edit... I would never call it "carve tool equivalent". Edited April 23, 2010 by mawi Quote Link to comment Share on other sites More sharing options...
kunal Posted April 24, 2010 Author Share Posted April 24, 2010 On 4/23/2010 at 10:27 PM, mawi said: When doing the extrusion you have to change from complete -> partial in the extrude option box(is that the name?). If you now look in you channel box you will have 2 inputs called subCurve1 & subCurve2. Animate the min/max values there. Edit... I would never call it "carve tool equivalent". Quote Link to comment Share on other sites More sharing options...
kunal Posted April 24, 2010 Author Share Posted April 24, 2010 thank you so much....that should do it and yes ur right....its not an equivalent ?(like most things maya), just a passable substitute Quote Link to comment Share on other sites More sharing options...
wiz79 Posted April 26, 2010 Share Posted April 26, 2010 On 4/24/2010 at 4:41 AM, kunal said: thank you so much....that should do it and yes ur right....its not an equivalent ?(like most things maya), just a passable substitute Kunal is using maya!.. oh NOes =) Ron Quote Link to comment Share on other sites More sharing options...
kunal Posted April 26, 2010 Author Share Posted April 26, 2010 (edited) hey Ron....sadly yeah i am using it fr this one project tell u the details later n sure hope to get back to houdini Edited April 26, 2010 by kunal Quote Link to comment Share on other sites More sharing options...
