holofernes Posted May 2, 2010 Share Posted May 2, 2010 Starting from prman 14, it's been introduced a new re-rendering method, similar to IPR. I was doing some research on how to implement this in Houdini, but reading the Houdini journals update log, I found out that this: Wednesday, May 21, 2008 Houdini 9.5.113: The renderman display driver has been modified to use a slightly newer version of the imdisplay protocol. It will not work with older versions of Houdini (i.e. prior to 9.5.113). However, without the newer driver, the mplay driver will not work correctly with prman 14.0 re-rendering technology (which is not yet supported in Houdini). I was wondering how are things now. Thaks, Fabio/ Quote Link to comment Share on other sites More sharing options...
