bhaveshpandey Posted May 6, 2010 Share Posted May 6, 2010 (edited) hey! i've only recently started dabbling with microsolvers in DOPS and have skimmed through the documentation but felt it's pretty scarce..(i do hope it gets updated) i'm trying out a Fracture sim and would like to control how the impact data is transferred within Object in DOPS.. for instance if i have a ball hitting the center of a wall, I would like to control how the Impact Impulse travels across the object thus controlling the regions for fractures.. i have thought of one approach..but i'm not sure if its any good.. first i defined a lookup field in sops using a volume which has a radial gradient from the center....which i import in DOPS using a SOP Scalar Field.. i intended to use something like a Gas Lookup which could lookup the field defined in SOPS based upon the Impact position data and thus scale the Impacts/Impulse data across the field..or something like it.. is this right approach for this kind of effect?? i also figured that I could try to modify the fields using a SOP Solver where i could then manipulate the volumes in Volume VOP..but since i wanted to explore DOPS in further detail ,i thought of throwing microsolvers into the mix.. any suggestions/tricks etc would be great cheers.. Edited May 6, 2010 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
