oldiesgoodies Posted May 6, 2010 Share Posted May 6, 2010 Hi Is it possible to get keep transferred attributes where they have showed up first after an att transfer Sop? Basically I want to keep the attributes where they have passed to, even if the source moves to somewhere else. This is not the effect I am trying to get but as an example basically think of it like brush painting a wall. The brush moves but leaves the paint behind. So I want the attributes to accumulate over the surface even if the source moves or new sources come by. thanks Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 7, 2010 Share Posted May 7, 2010 If you want to know how: search the forum for attribute transfer and sop solver. If you just want to use a tool that does it: http://www.sidefx.com/exchange/info.php?fileid=613&versionid=613 Quote Link to comment Share on other sites More sharing options...
oldiesgoodies Posted May 10, 2010 Author Share Posted May 10, 2010 If you want to know how: search the forum for attribute transfer and sop solver. If you just want to use a tool that does it: http://www.sidefx.com/exchange/info.php?fileid=613&versionid=613 Hi Thanks for the lead. I will check out the otl. I have tried searching the forum to locate that particular forum topic but I could not locate it. By chance you might have a direct link to it? thanks Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 10, 2010 Share Posted May 10, 2010 check out Peter Quint's video tutorial (vimeo) on sop solver to understand it better. This is where it came from: and this is useful too: And this one is fun too: Read this: Quote Link to comment Share on other sites More sharing options...
oldiesgoodies Posted May 11, 2010 Author Share Posted May 11, 2010 pclaes Thanks for your great help. These are some awesome stuff, both the otl file and the forum replies. Quote Link to comment Share on other sites More sharing options...
