daland_twist Posted May 8, 2010 Share Posted May 8, 2010 Hello, I am on Ubuntu running houdini. I would like to install HOT, but going to the download page there isn't a linux distribution to choose from. Does this mean I should use the source distribution for linux or am I missing something? thank you, david Quote Link to comment Share on other sites More sharing options...
eloop Posted May 8, 2010 Share Posted May 8, 2010 Use the source. -Drew On 5/8/2010 at 5:25 PM, daland_twist said: Hello, I am on Ubuntu running houdini. I would like to install HOT, but going to the download page there isn't a linux distribution to choose from. Does this mean I should use the source distribution for linux or am I missing something? thank you, david Quote Link to comment Share on other sites More sharing options...
daland_twist Posted May 8, 2010 Author Share Posted May 8, 2010 On 5/8/2010 at 7:57 PM, eloop said: Use the source. -Drew Thanks, I have installed the source, ran the python command, didn't see any errors while that happened. I was also successful with the star Sop test When I try to open the sop_simple.hip I get an error saying "Bad node type found: ocean in /obj/ocean" then there are a bunch of "skipping unrecognized parameter errors" Sorry to ask but does anyone have any ideas what I might be doing wrong? I am on Ubuntu 9.04 / Houdini 10.0.595. thanks -david Quote Link to comment Share on other sites More sharing options...
daland_twist Posted May 8, 2010 Author Share Posted May 8, 2010 On 5/8/2010 at 10:18 PM, daland_twist said: Thanks, I have installed the source, ran the python command, didn't see any errors while that happened. I was also successful with the star Sop test When I try to open the sop_simple.hip I get an error saying "Bad node type found: ocean in /obj/ocean" then there are a bunch of "skipping unrecognized parameter errors" Sorry to ask but does anyone have any ideas what I might be doing wrong? I am on Ubuntu 9.04 / Houdini 10.0.595. thanks -david Solved sorry everyone....pathing mistake on my part. david Quote Link to comment Share on other sites More sharing options...
