use img info to generate geo
I wanna give the motion to the img which comes from a photo (so is not a perfect img, such it has some noise,etc)
The question is:
I have to generate geos from the pic, so I have to fetch img or pixel color. Then extrude the geo based on the color
Another prob is, each piece should have separate ID, then I can give them a little random secondary motion.
One way I think about is copying box to POPs which will be scat from grid by color, then I can use rand() control the scale of each box
or maybe VOPs? I know VOPs can do it, but I dont know how.
Any idea or suggestion?
Maybe you can try this, it seems to work well.
I had to tweak your image to make it perfectly black&white, to have one pixel per unit, and square.
(Watch out, in my sample your pattern has change a little, so do it clean)
With this solution each pixel is a primitive so it should be easy to make random extrude or whatever you need.
Another solution could be to use trace SOP.
hope to help
ben
PixelColorToGeo.zip
hope to help
ben
Thanks, Ben! It is great! :D
Edited by Tong Le
