cooly08 Posted May 9, 2010 Share Posted May 9, 2010 (edited) Hi ! I'm new to Houdini. But I've spend some hours to understand how it works. I've a strange behavior. When I'm creating a null node (in obj level, in the viewport or anywhere else), my null is empty. Noramlly, there is a control and a point node (no ?). And my null node doesn't show up in the viewport of course (it's empty...). I've made a short video to show you the issue. I've made a fresh install of houdini and deleted all the file comming from hourini before. (I think so) Here is the video : (Same result if I'm using tab > utility > null in the viewport at obj level). I pressed h in the network editor to be sure nodes are hidden. Edited May 10, 2010 by cooly08 Quote Link to comment Share on other sites More sharing options...
edward Posted May 10, 2010 Share Posted May 10, 2010 Try moving aside your $HOME/houdini10.0 directory. Quote Link to comment Share on other sites More sharing options...
cooly08 Posted May 10, 2010 Author Share Posted May 10, 2010 Same trouble. This doesn't fixe the problem. :/ Quote Link to comment Share on other sites More sharing options...
