how do i create create dust using pyro
scorponok
i m trying to create dust from shatter object. I used vornoi fracture for shattering.Anyone pls. tell me how do i create dust from fracture pieces.I import a data from /obj/dopnet1/jl_fracturedpieces1/fractured_geo/OUT. I used this data as source for generating dust.I keep inside group and delete rest of the group then i extrude to give surface a volume.So i have control on dust generation when crack happen and dust coming out from that crack.But the problem is the data appear when crack create and ie. for one frame.
How do i generate dust like this reference image and motion too.I already generate dust using pyro but that is not from shattering object but from ground and its a nice output.so i m familiar lot with pyro.I m working on production so i cant upload the hip file.
Pls. reply me
Thanks.
Edited by scorponok
i m trying to create dust from shatter object. I used vornoi fracture for shattering anyone pls tell me how do i create dust from fracture pieces.
Check out the "Create Debris" shelf button under the "Create Particles" tab.
