particles rotation problem
blackchicken
the copy SOP is using "v" attribute to orient copies
that's why they rotate when they start moving
in rotation POP you can put your expression to Angle param and to axis Y just 1
but it would result in all feathers rotating around Y the same speed
you can use Angular Velocity POP for more controled rotation behavior, like according to speed you can increase angular velocity too
with some randomization on axis, or whatever you want
no matter what you use to rotate particles, you'll get "rot" attribute which is like relative offset to "v" for copy sop, so it won't help you much
but you can rename it to "orient" after POP network to get stable orientation of copies
look at the example
you can also just delete/rename "v" and "N" attributes if present
then "rot" will behave as expected
but you maybe need "v" for motion blur so the first solution is better i think
feather_02_fix.hipFetching info...
look at the example
Thanks for this information and for the file, with that I´ve learned more about the rotation too but I got a little confused about the orient attribute, I tried to look for the manual to see the difference between the orient and the rot attribute but I didn't find anything the could clear this, can you?
thanks
according to my experience it seems that:
"rot" acts like offset from rotation computed from "v" or "N" and "up" or "orient"
if "orient" is present, "v", "N", "up" are ignored and "orient" sets the whole rotation
if "orient" and "rot" are both present then "orient" sets the base rotation and "rot" acts like offset on top
