MENOZ Posted May 25, 2010 Share Posted May 25, 2010 hi, I can't see the help for the gas solver. I don't know how to use this node. I'ts similar to gas substep? thank you Quote Link to comment Share on other sites More sharing options...
bunker Posted May 26, 2010 Share Posted May 26, 2010 The gas solver is a more simple version of the gas substep (no substep or distribution) but it perform the same basic task. hi, I can't see the help for the gas solver. I don't know how to use this node. I'ts similar to gas substep? thank you Quote Link to comment Share on other sites More sharing options...
galagast Posted May 2, 2013 Share Posted May 2, 2013 Hi, I was following the Creating a Gas Solver tutorial, but I'm using H12.5 apprentice, and the Gas Solver DOP does not appear on the TAB menu and/or the Help file. The Gas Substep DOP worked as a substitute. I just wanted to drop my thanks for this post as it helped to let me continue the tutorial Thanks, Jeff Quote Link to comment Share on other sites More sharing options...
