raytheon Posted May 29, 2010 Share Posted May 29, 2010 hi all.. I've run hcustom on VEX_Ops.C on ubuntu karmic koala 64-bit and it compiles properly (i did add an include for UT_DSOVersion.h and changed the scope of getpid() to VEX_ALL_CONTEXT). I tried creating a new VEX geometry operator type and entering code with a call to getpid() but vcc cannot find a definition for it. The newVEXOp() function in VEX_Ops.C is not getting called. Is there something i'm missing? Maybe i'm not testing it correctly . thanks Quote Link to comment Share on other sites More sharing options...
raytheon Posted May 30, 2010 Author Share Posted May 30, 2010 Just as a check i compiled the SOP_Star example and it works fine. LD_DEBUG shows that the both sop and vex shared libraries are loaded by Houdini but a breakpoint set in newVEXOp() never triggers, though a breakpoint in newSopOperator() is hit. The LD_DEBUG logs (i've attached the entries which mention the sop and vex shared libraries) show that Houdini is checking for newVopOperator, newSopOperator, and a number of similar symbols, but never checks for newVEXOp. Has anyone been able to get the VEX_Ops example working on Ubuntu Koala 64-bit? Is there any additional information which might help to resolve this? thanks! sop.txt vex.txt Quote Link to comment Share on other sites More sharing options...
mrice Posted May 30, 2010 Share Posted May 30, 2010 Each vex library needs a corresponding entry in a VEXdso file. I think its a way of making sure things aren't too easy. There's an example in $HFS/houdini/vex Also a bit of info here Quote Link to comment Share on other sites More sharing options...
raytheon Posted May 30, 2010 Author Share Posted May 30, 2010 Thanks.. that fixed it! The LD_DEBUG log now shows that Houdini is hooking newVEXOp. I had seen the section on index files earlier, but blitted over it because the word "obsoleted" is in bold in the first sentence . Digging into it a bit further, there is $HFS/houdini/vex/dso/VEX_VexOp.html, which is quite detailed. This content doesn't seem to be indexed by google. It would be nice if the VEX_Ops sample included a VEXdso file or a readme. Quote Link to comment Share on other sites More sharing options...
