lost model in viewport
quarel
Hi all!
I need some help! I imported the dxf model into Houdini but it is very far from central grid. Simply it's lost somewhere in space . I can focus of course on imported model or on grid plane . but how to center the model into grid without manualy trough move handle?
Go inside the object node for your geo and append a transform SOP.
After you have done that, you can use the origin() expression to query the objects position in world space and transform your geometry to the center by negating that number.
So tx, ty and tz would be:
-origin("","..", "TX")
-origin("","..", "TY")
-origin("","..", "TZ")
You can center the pivot point of the geometry using $CEX, $CEY, $CEZ in a the same transform SOP.
or just use -$CEX, -$CEY, -$CEZ in the transform SOP :P
ou, this is much easier. But thanx both! I haven't time to reply thnax;)
but anyway..why it is only trough hscript, why isn't there some quick menu command?
