kursad Posted June 4, 2010 Share Posted June 4, 2010 (edited) Hi I am trying to bring an illustator object in Houdini. I think that most of the stuff works as expected, except when I create attributes for points on the illustrator file. Some curves get the point attribs fine, but some stuff never accepts any attribute and defaults to zero. Here are some screenshots. The numbers in the viewport are supposed to be $TY of the points on the sampled .ai geometry. As you can see some points have the correct values, but those that are branching out are falling into zero value. Edited June 4, 2010 by kursad Quote Link to comment Share on other sites More sharing options...
