pcopen - once again
sanostol
Hi, I'm trying to get this working for some time right now, but without succss.
I use the pcopen function, but I want to use the not very well documented "ndot" argument. My goal is to get every point to use a look direction and cone, so that every point has a limited angle of view. only points of the point cloud that are inside this cone are considered, but I don't get it to work.
my function looks like this:
int handle = pcopen(pcFile, pChannel,P, nChannel, N, maxdistance, maxpoints,"ndot", cos(radians(coneangle)) );
how can I achieve this effect?
martin
You have to do that manually, the pcopen does not support it.
It will make its' selection on all the points facing in the same-ish direction, rather than select the points in the "field of view".
So to do it manually:
*)open a normal pointcloud, big enough to encompass all the points in the sphere of influence (both in radius as well as in amount of points).
*)setup your pointcloud while loop and pcimport the P.
*) calculate the direction vector from current point A to imported point B =>
B-A
(you do not want to normalize this yet as you will want to use the length of this direction vector (effectively the distance to the other point) as a weight - similar to what the pcfilter does )
*) compare the original vector from A with the direction vector to B =>
dot( normalize(A) , normalize( )
*) the result of the dot product will be ranging from -1 to 1, a result of 1 means the point is right in front of A, 0 means it is perpendicular (at 90degree angle), -1 is behind A. You can use ramps or fit functions to remap the influence based on this.
*) To make it a bit more user friendly you may want to use degrees instead to specify that angle of influence. From the
dot(A, = |A|.|B|.cos(alpha)
follows (if you are using normalized vector which you should)
alpha = acos(dot(A,)
. Alpha will be returned in radians.
*) Then with an if statement you can reject:
if( alpha > degreesToRadians(60))
Overall it's still pretty fast as you are still using pointclouds to narrow the huge cloud to the sphere of influence.
Edited by pclaes
