Environment var: prepend?
efecto
I got HOT to work on my windows7(x64). It's really great! Thank you.
During installation, I had another PATH variable and I temporary nuked it to get the HOT to work.
In your doc, it says to prepend the entry above.. but I don't really understand what you mean by prepend.
could you please tell me how to prepend?
Thanks!
doc:
http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/
  Quote
HOUDINI_PATH c:/hotbin_win32_H10.0.374;&
PATH c:\hotbin_win32_H10.0.374\dlls
Note: Don’t nuke your PATH if it already exists, prepend the above entry with a “;” between the entries.
under linux it's like:
setenv PATH /home/pclaes/bin:$PATH
Where ":" allows to add different paths and "/home/pclaes/bin" is prepended to the PATH variable. Not sure about windows, but can't be too different.
By prepend I mean, e.g. if your PATH was originally set to something like -
PATH c:\MyFaveApp
then you would prepend the HOT's dll folder to the PATH by setting -
PATH c:\hotbin_win32_H10.0.374\dlls;c:\MyFaveApp
You have then put both folders on the executable path by separating them in the PATH variable with a semicolon.
-Drew
Thanks!
doc:
Edited by eloop
