Lukich Posted July 23, 2003 Share Posted July 23, 2003 Hi. Does anybody know if it's possible to change the beginning and end of an IK handle. Let's say, I creat a 4 joint setup with Inverse Kinematics enabled. Can I then change the IK handle to go from bone 2 to 4 or 1 to 3? Thanks a lot, Luka Quote Link to comment Share on other sites More sharing options...
anakin78z Posted July 23, 2003 Share Posted July 23, 2003 Yes. If you create your chain with no kinematics, go into the bones tool, select inverse kinematics from the dropdown list, ctrl-right click in the viewport and select 'add kinematics'. From there on just follow the directions and it'll add the kinematics for you. If you already have kinematics on your chain, you can also remove any kinematics and end effectors. -Jens Quote Link to comment Share on other sites More sharing options...
Lukich Posted July 23, 2003 Author Share Posted July 23, 2003 Cool! Thanks a lot! Quote Link to comment Share on other sites More sharing options...
