Render pass
hi everyone ! I have been trying to make an underwater sequence. I have generated a caustic map through the Spot Light, using projection under spot light options. I want to render out the caustics into its separate render pass so i can comp it over and tweak it. I do not know what approach to take to render out only the projected caustic map.
P.S - rendered image to get an idea
Thanks in advance
Thanks in advance
hi ! I tried what you told me, the result is only a black frame. What I tried is to render out a single frame without projection and another one with red light having the projection then used Luminosity blending to make it look like caustic pattern.. I don know if this is the right way to do it ?
