Macha Posted July 27, 2010 Share Posted July 27, 2010 When I cycle an imported sequence of images I noticed that it cycles everything that comes after the node as well. For example, I mirror-cycle a background image so that it continously loops but when I add another node (say bright) and animate it then that node is also cycled. If I override that behaviour in the frame scope then the whole thing stops cycling again. What shall I do? Quote Link to comment Share on other sites More sharing options...
malexander Posted July 27, 2010 Share Posted July 27, 2010 Use an Extend COP to increase the frame range of the sequence to the length you want. After that, you can change the extend conditions to whatever you like (black, hold, etc) and it won't affect the frames inside that new range. Quote Link to comment Share on other sites More sharing options...
