copying several points to popnet using copy SOP?
Guest ravin
Guest ravin
I am trying to copy several small spheres to popnet particles using a copy SOP. So lets say I have 10 particles moving under a force, and I want to copy 100 small spheres to each one of them such that it appears that 100*10 particles are being influenced. Using the copy SOP how can I distribute these spheres around each particles in a random and well distributed order and give them slight random movements?
thanks,
I don't have Houdini on this machine so I can't send you a file but if I understand you correctly you could probably create a stamped random vector and add that to the spheres' original position. During animation you could add noise, rather than random movement, to it with an expression or a chop.
Edited by Macha
Guest ravin
Hey,
I am able to attach the spheres to the particles as per your advice. How can I add noise so that the copied particles instead of maintaining a constant offset, have some movement? If you could send me an simple example whenever you are on a machine that has houdini, that would be great. I am also attaching my file which is a very simple setup.
thanks,
Guest ravin
Hey,
thanks,
This is the attachment I mentioned in the above reply.
copyMillionParticles.hip
Create your vectors and append a vopsop with a Transform Matrix node. Plug the vector into the position and promote the Rotate channel. Then you can rotate your vector on that vopsop. Perhaps right-click on the channel and add a motion effect.
Simple file attached. Sorry I couldn't do more for the moment.
quick.hipnc
Edited by Macha
Guest ravin
Thanks for the help.
