mrice Posted August 6, 2010 Share Posted August 6, 2010 How is this done in the fur and volume procedurals? It looks like VOP_CodeCompilerArgs holds the file path, but when I try to access a parameter with the path to the cvex shader,the shader is being evaluated, rather than the call returning the string. ie *getSParm("shader") returns "op:/shop/cvexShader density 1 P 0 0 0" instead of "/shop/cvexShader" VRAY_Procedural::import() does the same. much appreciated! Quote Link to comment Share on other sites More sharing options...
mrice Posted August 6, 2010 Author Share Posted August 6, 2010 Thinking more about it, the path to the cvex shader is probable being expanded before mantra sees it.. Quote Link to comment Share on other sites More sharing options...
