Guest ravin Posted August 9, 2010 Share Posted August 9, 2010 Similar to billowy smoke shader which is present by default, is there any shader I can use for dust rendering? If I apply an isoOffset on a geometry node and apply a billowysmoke I get cloud looking shape, is there anything similar for dust? thanks, Quote Link to comment Share on other sites More sharing options...
Netvudu Posted August 9, 2010 Share Posted August 9, 2010 (edited) I think the default shader for dust is sprite-based, but you probably can use a constast volume smoke shader for something like that. Or even better, use both, and blend in compositing. Edited August 9, 2010 by Netvudu Quote Link to comment Share on other sites More sharing options...
