object subnet bug in H6.1?
Hi, I noticed a difference in the H6.0 and H6.1 behavior concerning object subnets. If you create a null, make a subnet with him and set the output transform of the subnet to this null, I have an "infinite recursion in evaluation" ( the null only gets red, not the subnet ), and I cannot use the output transform of this subnet...
I hope I was clear.
This was a simple case, but I had a few OBJ OTL using this behavior, and they worked under 6.0, but they can't be used in H6.1. Is it an expected behavior? is there a work around?
