goshone Posted August 27, 2010 Share Posted August 27, 2010 As I was going thru the new features list, I read about the 'Property' SHOP, and proceeded to click thru and investigate. The link was red and gave me a 404 Error. I also can't find it in the SHOP list, only 'properties' which looks a bit hacky, with no icon and no parameters. I could very well be an installation issue, but does anyone else have this issue? Thanks Josh Quote Link to comment Share on other sites More sharing options...
anim Posted August 28, 2010 Share Posted August 28, 2010 i am not aware of Property SHOP but it looks like it should be Properties SHOP what's new in H11 is Properties VOP which can be used inside Material Shader Builder the same way as Properties SHOP before and yes, it's empty by default, all rendering properties you can add through gear menu http://www.sidefx.com/docs/houdini11.0/nodes/shop/properties Quote Link to comment Share on other sites More sharing options...
Nerox Posted August 28, 2010 Share Posted August 28, 2010 I use properties VOPSHOP mostly for adding a displacement bound parameter. What it basically does is it enables you to scale the objects bounding box, if you don't then the mircopolygons which are displaced outwards might be cutoff because they end up outside the objects bounding box. You can easily drive this parameter by channel referencing the scale attribute on the 'displace along normal VOP'. The 'displacement bound' parameter can be simply added by editing the properties nodes parameter interface (right click, edit parameter interface). Then on the 'For Rendering' tab look for 'Mantra 11.0/Shading/Displacement Bound', click the right pointing arrow and hit accept. No all is left to do is to create a channel reference to the displace along normal/scale attribute. Attached you'll find an example file, the blue displace sphere has holes in it. This is due to the missing properties VOPSHOP, the red one displaces correctly. displacementBound.hip Quote Link to comment Share on other sites More sharing options...
goshone Posted August 31, 2010 Author Share Posted August 31, 2010 Ahh, yes, I must have read it wrong (unable to find the page in help where it used 'Property'), but that makes sense. Thanks for clarification. Quote Link to comment Share on other sites More sharing options...
