Vex signatures and function returns
Hi guys,
I am stuck with my vex signature. It is a displacement shader and I want to return the new point coordinates.
First obvious change would be to have my function a return type of GEO_Point but then the VEX_Vexop starts to complain heavily in gcc. That does make a bit of sense since in the vex environment there is no GEO_Point type. Closest thing there is a Vector4 but UT_Vector4 or the VEX_TYPE_VECTOR4 don't work either. So what's the trick here?
static void hh_gnoise(int argc, void *argv[], void *data)
        //...lot of code above...
        UT_Vector4 pos((pt->getPos().x() +f),(pt->getPos().y()+f),(pt->getPos().z()+f));
	GEO_Point *pout;
	pout->setPos(pos,1);
	//return pos;
void newVEXOp(void *)
	new VEX_VexOp("gnoise@*PPVFIFFFFFFFFFFF",hh_gnoise, VEX_DISPLACE_CONTEXT,NULL,NULL,VEX_OPTIMIZE_2,true);
And a 2nd question. After compiling the code, i just can copy the .so file to somewhere on my $HOUDINI_DSO_PATH and it gets picked up in Vex? Or do you also need to "register" it somewhere else? (which i thought you should; i thought i came across some post where you had to edit some file to make it all work but can't find it anymore).
Thanks,
Hans
  • 3 weeks later...
You need to create a vex/VEXdso file in your houdini directory (i.e., ~/houdini11.0/vex/VEXdso) containing entries like,
vex/my_dso_with_vex_declarations.so
Basically, a relative path pointing to your dso within the dso directory (so, we'd have the dso at ~/houdini11.0/dso/vex/my_dso_with_vex_declarations.so)
GEO_Point, like you said, isn't a vex type, so I wouldn't even bother exploring that avenue. Instead, try something like this:
static void rand_test(
    int argc,
    void** argv,
    void* data)
    UT_Vector4* result = reinterpret_cast<UT_Vector4*>(argv[0]);
    int seed = *reinterpret_cast<int*>(argv[1]);
    srand(seed);
    result->assign((rand()%100)/100.0,
                    (rand()%100)/100.0,
                    (rand()%100)/100.0,
                    1);
void newVEXOp(void*) {
    new VEX_VexOp(
        "rand_test@&PI",
        rand_test,
        VEX_ALL_CONTEXT);
  • 3 weeks later...
  • 2 weeks later...
It's a pain, but the cool part is that you can query all of configured DSO symbols outside of Houdini:
vcc -X SOP
It's much easier to debug these problems when you don't have to wait for Houdini to load to see if your VEX functions are recognized or not. :)
Edited by Vormav
vcc -X SOP
Tyvm sir, that does indeed save me some time :D
Cheers,
Hans
