How do I get the system time in Windows?
LFX
I know there is the system() expression, but the only thing that works is system(time), not 'time /t'.
Edit: Or do you know another way to check how much time has passed since the last cook of a node?
Edited by LFX
you can use python for that, for example
import time
print time.time()
will print time elapsed since epoch in seconds. see the documentation of the "time" module for much more options:
http://docs.python.org/library/time.html
there is also a "datetime" module which allows you to do complex manipulations on objects representing time points or ranges.
  • 2 weeks later...
