VOP ramp bug?
I'm having some trouble doing something with H11 that was relatively simple in H10. Using a vop spline ramp which uses a custom attribute to model geometry. For some reason I keep getting an error. Has something changed in H11, or is this a bug? If working properly, the ramp should be able to interactively scale each copy of the circle being copied using the attribute value of each point on the template line as a lookup. Hard to explain, see attached file
test.hipnc
what error are you getting?
it's working perfectly fine here
H11.0.504 Win64
Weird, Im running the exact same setup and its not working for me, even when I start a new file from scratch. Are you on windows 7? Im getting a whole host of errors, it saying "unknown parameter" for just about every parameter that could be in there--about 15 or 20. It says they are all "undefined symbols". bah
maybe I need to upgrade versions of H11. since its working for u, this makes me think it might be a windows 7 thing. To be clear, my setup is windows 7 x64 with H11.0.504
Can u confirm what version of windows u have. thanks for having a look
exactly the sam H11.0.504 Win 7 x64
and on my laptop it works ok too H11.0.514 Win XP x32
i am just getting output to the console "success: 1" several times due to print VOP inside, but no errors
Edited by anim
Still having problems. When i use the print vop, and click output to console, nothing happens. Its as if my console is broken. Just tried installing 11.469 and still getting the same errors when I try to use the vop ramp. here's the errors Im getting in the vopsop:
unknown parameter 'ramp_the_basis_strings' undefined symbol
unknown parameter '(' undefined symbol
unknown parameter 'linear' undefined symbol
unknown parameter ')' undefined symbol
unknown parameter 'ramp_the_key_positions' undefined symbol
unknown parameter '1' undefined symbol
unknown parameter 'ramp_the_key_values' undefined symbol
unknown parameter '0' undefined symbol
unknown parameter 'sc' undefined symbol
If anyone has a clue as to what this means, or how to fix it, I'd really like to know. Never got these errors in H10 when I did this.
