How to add a value to a channel reference
LFX
Hello there,
I found an expand function a little while ago, which gives the parameter field a dashed border and then you can add a value to the channel reference via the slider. I can not find it anymore.
Anyone?
Hmm, I must have mixed sth. up. Nice feature anyway, to see the result of an expression in a string parameter.
But now I doubt that there is any way for my request - to use the slider in a numeric parameter to add a value to the expression that's lying in there.
No, that's the way I do it now. Would be really convenient if I could choose a value in the expression which I can set with the parameter slider.
Thanks anyway.
Edited by LFX
Ah OK, I see what 'you' mean.
But now I have a second slider. Is there anyway to hide only the slider resp. field, or can I only hide the whole parameter with the expression? Which would be bad, as this contains the result I like to see.
Edit:
Found a good compromise. I make a two float parameter and use the second to set the value in the expression. Anyway a slider would be the right thing, as I only want to see the result.
Thanks Macha, for taking me in the right direction.
Edited by LFX
