baked displacment, banding truble
Sebbe
Hi.
Im baking a displacment texture using mantra with the "UV object" parameter added.
it bakes just fint but i got heavy banding in the result. i tryed 16 and 32 bit exr
and i got the same result so it works just the way it should!
im using a super simple shader thats takes teh Y-position of the object in worldspace as output color.
i also tryed to pick up the Cd from the object as output color in my shader and i got the same result....heay banding!!!
even if i make the objects topology super dens the banding is the same.
anybody know how to solve this or had the same problem???
tanx
