Offset creation time of copied simulation?
jont
I have a simple simulation that I want to bring in to sop level and copy to multiple instances. But I want the start of each instance to be off set by 5 frames from the previous instance.
The sim is cached, I use dopimport to bring it to sop level and then apply a copy sop. I need the copies to appear, one after the other, alone the points of a curve, and this is where i get stuck.
Any help?
Thanks
you could attach a timeshift SOP between your dopimport SOP and the copy SOP,
then in the copy SOP create a 'stamp input' called 'pt' => $PT and
in the timeshift SOP frame parameter write something like this: $F-5*stamp('../copy1','pt',0)
Cheers,
Emanuele
Edited by Emanuele Berti
