MENOZ Posted November 5, 2010 Share Posted November 5, 2010 hi, I think I have not fully understood the Sop geometry DOP. Is there a way to visualize the "imported" sop in my Dop context? Is there a way to modify the position of this geometry? the "position data path" parameter is not explained in the help.. what this refers to? if I try to apply data from a position DOP it doesn't work.. Quote Link to comment Share on other sites More sharing options...
Morbid Posted November 24, 2010 Share Posted November 24, 2010 hi, I think I have not fully understood the Sop geometry DOP. Is there a way to visualize the "imported" sop in my Dop context? Is there a way to modify the position of this geometry? the "position data path" parameter is not explained in the help.. what this refers to? if I try to apply data from a position DOP it doesn't work.. You can visualize the geometry in DOP level by connecting a Rendering Parameters node to the SOP Geo DOP. The Position Data Path refers to the position of the imported geometry, it fetches the position data from the geometry. Just leave it as default. If you want to change the position of the geometry then just do this on SOP level. Quote Link to comment Share on other sites More sharing options...
