NatXotic Posted August 15, 2003 Share Posted August 15, 2003 When setting the graph from cubic to spline, the geometry isn't taking the info from the controls anymore (those who have been set to spline). Anybody noticed that? Quote Link to comment Share on other sites More sharing options...
edward Posted August 17, 2003 Share Posted August 17, 2003 The spline() function in graphics terminology implements a "natural cubic spline" (lots of hits on google). It is designed to fit through all the keys globally across the entire _channel_ while ensuring smooth conditions. The typical use of spline() is convert all the keys in the whole channel to spline(). Using natural cubic splines, we can very easily fit a set of data points smoothly. However, it's generally not very desirable for animation since it can easily overshoot. If you're using H6.0, then one thing we added was an easy way to smooth slopes on cubic() keys without overshoot. Simply select all the slopes and hit the 9 key to smooth them. Quote Link to comment Share on other sites More sharing options...
NatXotic Posted August 17, 2003 Author Share Posted August 17, 2003 ok, i know what splines are (wrote a paper on genetic algorithms for splines) and thanks for the tip with the "9". But why do the handles jump back to the default state, if i keyed them previously and just change the curve in the grapheditor to spline? You should be able, even with an overshoot to keep the set keys. I use 6.1.83. Well what i did now was going in there and manualy change every single slope to what ever i like it, tedious but was necesary to get rid of some jaggy character movements. The spline would have been nice, even with an overshoot for my characters tail. But thanks anyhow. Quote Link to comment Share on other sites More sharing options...
edward Posted August 18, 2003 Share Posted August 18, 2003 I still don't understand. How are the handles jumping "back to the default state"? Slope has no meaning to spline(). Please provide a concrete example. I'll start. - create new channel with key at frame 1 - scope it in the channel editor - change time to frame 10, hit k to set a key - do the same at frames 20, 30, and 40 - hit h to home the entire channel - change the keys to these values: frame 10: 1 frame 20: 2 frame 30: -1 - hit h again to home - select all the slopes and hit 9 to smooth them - change the segment between frames 10 and 20 from cubic() to spline() - this gives you a straight line because it is only fitting two data values. notice that no slopes have changed. For the slopes belonging to the spline(), they're hidden because they no longer have any meaning. - change the segment between frames 20 and 30 to spline() - this now gives you a smooth curve fitting 3 data points - again, no slopes have changed but ones that are not used anymore are hidden Quote Link to comment Share on other sites More sharing options...
NatXotic Posted August 18, 2003 Author Share Posted August 18, 2003 oki, i attached a file so that you can see what happens. If you try to move one of the persistant handles you will notice, that they do not influence the bones. Once you go into the channeleditor and change the type from spline to cubic, they change will appear. I don't need the spline anymore, so that's fine for me, but should houdini react like that? It really confused me, till i noticed what was going on. example.rarFetching info... Quote Link to comment Share on other sites More sharing options...
edward Posted August 19, 2003 Share Posted August 19, 2003 Ah, you mean the *viewport handles*. I always assumed you meant something in the graph editor. There seems to be some unexplained bad interaction between the viewport handles and the spline() function. If you move the handles after loading the file you will note that all the bone tiles in the network editor show warning messages. If you then dive down into the curve geometry object, you will see red errors. Quote Link to comment Share on other sites More sharing options...
NatXotic Posted August 19, 2003 Author Share Posted August 19, 2003 Unexplained, that means you still don't know where the error comes from, or what causes the error? Well, as i did the animation in another way, it's not that important to me anymore. Just wanted to know if there is an explanation for that. So it seems that that's a bug? Cheers and thx for your kind help. Quote Link to comment Share on other sites More sharing options...
edward Posted August 19, 2003 Share Posted August 19, 2003 Could you try this in build 101? thanks. Quote Link to comment Share on other sites More sharing options...
NatXotic Posted August 20, 2003 Author Share Posted August 20, 2003 flew outta twon, will try when back home. Quote Link to comment Share on other sites More sharing options...
