methods to simplify geometry
Barakooda
I`m looking for better methods to simplify this organic shape like this example i made.
New Ideas are very welcome !
Extra:
I`m looking for away to code this simple algorithm in Houdini :
or even use the "for each" node...
Group B Append point0 from Group A.
Delete Point 0 from Group A
N=number of point in group A
for C in (1 to N):
"point"= (point in groupA that have the smallest distance from the last object in groupB)
append the "point" to group B.
point number of this "point" in group B will be C
delete "point" from group A
you can see where it can be handy in my project file and many other to come.
if there is already node that can do it easily Smile i will happy to know about it.
simplfiy_geometry.hipnc
On second thoughts, I don't know if you simply can re-assign $PT... In that case, perhaps a little python script like so could work:
-add pt0 to a list
-for last entry in list find and append nearest neighbour (that is not in list) to the list
-loop through the list and create a polygon
That way you should get a curve that fits the previous one exactly with the points sorted correctly.
Thanks mate, i thought maybe there is more straight forward way to do it.
If some one have work-flows to simplified geometries and want to share it here , please feel welcome !
i will find time and i will implement this little sort code and will share it with you all.
B.
  • 2 weeks later...
