MENOZ Posted November 13, 2010 Share Posted November 13, 2010 Hi. taking as example the sop solver documentation I find DATAPATH : This is the full path to the piece of data within the DOP Network that is being solved by the SOP Solver. It is equivalent to $DOPNET:$OBJID/$DATANAME. and an example By using an expression like stamps("../OUT", "DATAPATH", "../.:objname/Geometry") in an Object Merge SOP, the output of the previous timestep can be used as the starting point for the next timestep within the SOP Network. The column is used to "dive inside" a node? I don't understand. Quote Link to comment Share on other sites More sharing options...
anim Posted November 13, 2010 Share Posted November 13, 2010 data referencing in DOPs is explained here http://www.sidefx.com/docs/houdini11.0/dynamics/io#id321393 Quote Link to comment Share on other sites More sharing options...
