bounce and not freeze
MENOZ
hi, Im making some tests with dops.
I'm activating objects using an animated attribute in sop.
I noticed that when objects are activated and bounce on inactive objects the bounce is very high, causing instability and strange behaviours.
Using a simple scene with an inactive rbd plane and a active sphere the problem doesn't show up.
in the video it shoud be clear..
briks.mov
Could it be that the inactive objects act as perfect springs with no energy loss? How about applying a drag force, perhaps only for a group?
well, yes, it seems so.
You suggest to add a drag force only to those object that bounces on inactive objects?
I will try to use a switch solver instead of drive the activation.
could this be a bug?
EDIT: even switching the solver brtween static and RBD tha behaviour is the same.
Edited by MENOZ
How about you just reduce the force of your initial state. To me it looks like those jumps are just a result of those values, no?
No, I set the initial velocity so the active object can jump on the inactive. if you let the simulation go for a while, you will see that the pieces never stop to bounce over the inactive pieces.
does it is the case to sens the hip file to sidefx?
It seems a bug..
Hm, I don't really know the answer to this...sorry. If you can reduce the problem to a minimal amount of nodes and expressions, perhaps that helps. At the moment it is a little hard to figure out which bits are superfluous in isolating the problem.
Edited by Macha
