Lyonz Posted November 20, 2010 Share Posted November 20, 2010 Hi all, When creating image planes is there a way to disable the C plane as this renders the entire scene when all i need is the image planes ? Lyonz Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 21, 2010 Share Posted November 21, 2010 Hi all, When creating image planes is there a way to disable the C plane as this renders the entire scene when all i need is the image planes ? Lyonz You have to render the entire scene to store the extra image planes. They are just a component of the final calculation. Quote Link to comment Share on other sites More sharing options...
Lyonz Posted November 22, 2010 Author Share Posted November 22, 2010 You have to render the entire scene to store the extra image planes. They are just a component of the final calculation. Yes I understand but is there a way to only render the image planes ? As otherwise was going to create separate takes for each. Thanks Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 22, 2010 Share Posted November 22, 2010 Yes I understand but is there a way to only render the image planes ? As otherwise was going to create separate takes for each. Yes you can, well, sort of. You want to write the main image out to a NULL device, but enable saving to disk for the image plans. On the Windows OS you can save the image as "nul", and on Linux you can save it as "/dev/null". Don't define the file extension, but select something in the Output Device (like JPEG for example). Mantra will generate an error when trying to save the image (can't close output file). So if your using a render farm manager, then you'll want to disable aborting on errors. Otherwise, Mantra will continue as normal. For each image plane, you need to enable the "Different File" option and save the image plane to it's own file. That's the best solution that I can think of. Quote Link to comment Share on other sites More sharing options...
Lyonz Posted February 11, 2011 Author Share Posted February 11, 2011 Thanks for the reply will test this out. Quote Link to comment Share on other sites More sharing options...
