pre-render raise ValueError
com48
Hey guys,
I'm trying to stop my rendering of a rop. i'm calling a python module on disk and no matter what I try it will not influence the render of the output.
raise hou.ValueError()
sys.exit(1)
return 1
nothing seems to influence the rop.
is it possible to stop a rop from rendering with python or hscript from the pre-render field? or is there a better way of doing this?
greetings,
Lars
so it seems that the pre-render script and the pre-frame need to raise a error to stop a node from rendering.
raising a error on the pre-render will stop the node from rendering the next node in the chain.
raising a error on the pre-frame will stop the node from rendering the current node.
hope it helps someone else.
greetings,
Lars
  On 11/23/2010 at 3:28 PM, hopbin9 said:
How do you raise an error in a script? That's something I've never done.
set the pre-frame script to python and type:
raise Exception("STOP!") #Hammer time
Stops the node.
adding it to the pre-render will stop the next node from rendering but not the current node. SESI informed me today the fix the bug i reported yesterday so todays build should have some of this weirdness solved.
